Re: Little Genius Plowing Video
Posted by PurdueAg on April 17, 2008 at 19:34:23 from (198.109.220.6):
In Reply to: Re: Little Genius Plowing Video posted by LA in Wi. on April 17, 2008 at 19:15:38:
Hey Lowell,
Thanks for the tip. I finally fixed the spelling of your last name on the Little Genius webpage! Post some videos of that plow day if you can. I had a blast out there in the field the last couple days. Also just bought a McCormick-Deering No. 9A disk and got it fixed up enough to use. I'll restore it this summer.
Tony
