i take it you have good spark. like when you move the lever to the gas side you will see the amp. meter flick a little to discharge.on diesel the spark is cut off.you didnt say if you had the carb apart.sounds like you just checked the needle and seat, by blowing in it.there could something actually in the jet causing no fuel to be sucked into the venturie.nothing really in those little carbs for parts. i would give it a soaking in carb cleaner and rinse in water and blow out the passages good with air.if you have spark and fuel you should get an explos ion.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
