Re: Farmall H ignition question
Posted by Brownie450 on April 20, 2008 at 10:00:26 from (216.51.158.251):
In Reply to: Farmall H ignition question posted by Mertel 7 on April 20, 2008 at 07:45:26:
Check the regulator mounting tabs to see if it is a pos or neg gnd regulator. It should have 6v pos or just P if it is 6 volt positive ground-----or 6v Neg or just N for negative ground.
This is assuming it still has a 6-volt system. If the regulator is a 6 pos---you will have to reverse the battery cables.
