Re: Farmall H trans stuck in gear
Posted by HAS on April 20, 2008 at 11:46:19 from (68.12.173.235):
In Reply to: Farmall H trans stuck in gear posted by Rod Morris on April 20, 2008 at 11:38:53:
Ours does that too. Sometimes you can rock it back & forth by pushing by hand on the rear tire and get it loose. You really need to pull the shift lever, build it up with weld and then grind it back smooth. It has worn too short to engage the shift rails. If yo do a search on here you will even see some pictues of how is supposed to look when you are done.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
