Re: Farmall H engine question...opinions needed.
Posted by CNKS on April 20, 2008 at 13:23:45 from (216.144.104.128):
In Reply to: Re: Farmall H engine question...opinions needed. posted by Jesse on April 20, 2008 at 13:16:25:
If it is antifreeze, your oil is contaminated, and you have a blown head gasket, cracked head, or some way that antifreeze is getting into the oil. That has to be fixed. If it is oil, that is common, won't hurt anything unless it is leaking a stream. Most tractors seep or leak oil somewhere. You might gently tighten the bolts, or get a new gasket. The oil leak is an easy fix, antifreeze isn't.
