Fred, see my answer to your other post, how will jacking the engine move the gear out of your way? Step back, take a breath, look from the bottom should be space to remove "gear" from front pulley. MAYBE remove pump from loader frame and pull "gear" forward, I have yet to see any accessories that require "jacking up the engine or disassembly" of the front end to replace a belt. Lots of these old tractors around that had the selling point of ease to work on, no computers, simple hydraulics, simple electricals, so the owner could repair himself and keep working.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
