Re: Farmall-H Fan belt problems
Posted by Dick fm Iowa on April 21, 2008 at 03:48:46 from (75.163.65.175):
In Reply to: Re: Farmall-H Fan belt problems posted by garytomaszewski on April 20, 2008 at 13:26:37:
I believe his problem is a gear has been added in front of the crankshaft pulley, maybe it was added while the engine was removed, which might very well mean it can't be removed in the frame.
