Re: MD Starting on Gas Blues Part 2
Posted by garytomaszewski on April 20, 2008 at 13:53:41 from (4.158.174.149):
In Reply to: MD Starting on Gas Blues Part 2 posted by Matt Compton on April 20, 2008 at 08:33:17:
Matt, I'm thinking you have some valve problems on the gas side possibly from the diesel needing adjusting to shut off while starting. With choking you should be able to flood the plugs! Try the gas in plug hole trick, if that works you have to figure out why you aren't pulling gas in while cranking. Maybe put some Marvel Mystery Oil in the gas and run it on gas for a while. Don't remember if we shut it off on gas and no longer have one or a manual but don't think so. Maybe try a small propane torch UNLIT in intake while cranking, would tell you if you need to look at fuel supply problems.
