Re: replacing oil seal in super h rear end
Posted by Wayne in MN on April 20, 2008 at 20:52:54 from (68.119.27.241):
In Reply to: replacing oil seal in super h rear end posted by Andrew Kappers on April 20, 2008 at 20:17:40:
The coupling nut loosens by turning left (counterclockwise). Lock the brakes & put the transmission in reverse before trying to loosen the nut.
It is tight because as the Lift-All is used, the nut is forced tighter each time due to rotation of the shaft.
Be patient and get a bigger wrench!
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
