Re: MD Starting on Gas Blues Part 2
Posted by KEB1 on April 21, 2008 at 07:21:06 from (192.91.171.36):
In Reply to: MD Starting on Gas Blues Part 2 posted by Matt Compton on April 20, 2008 at 08:33:17:
Check the impulse on the magneto. That's about the only thing I can think of that's different between starting on gas & running on gas after switching from diesel to gas. If the impluse isn't working, you'll have a hard time getting a good spark at cranking speeds, but it will work just fine at idle speeds.
You should be able to hear the impluse click as you crank the engine. Have you checked to make sure you have a good spark at cranking speed?
Keith
