Re: 700 Plow
Posted by Hugh MacKay on April 22, 2008 at 02:41:37 from (216.208.58.103):
In Reply to: 700 Plow posted by turklilley on April 21, 2008 at 19:24:05:
turklilly: You must have the plow model wrong, 700 is a trailer plow available only in 7, 8 or 9 bottom sizes.
Your plow must be a 510, 710 or 720, most likely 510 or 710. The 720 was only available with toggle trip or automatic reset. You should be able to adjust that plow to suit anything between 72" and 84" tractor wheel tread. If your running less than 72" on the tractor, I don't think you'll ever get it set right. You may get it set right to plow right, but it will not pull easy.
