Re: H quits after only minutes of running
Posted by RockyMO on April 22, 2008 at 05:27:10 from (24.216.122.188):
In Reply to: H quits after only minutes of running posted by 160dan on April 21, 2008 at 20:33:45:
Since you say the battery is dead and worthless after the engine dies, I suspect the charging system is not working. You mention a 12 volt conversion so I am led to believe that you have a distributor not a mag. A distributor requires battery voltage to run. If the battery goes dead the tractor will die. Just my thoughts, and please remember they are worth exactly what you paid for them.
Rocky in MO
