Re: Farmall 706 Hydraulics
Posted by bc on April 22, 2008 at 08:00:30 from (75.27.227.23):
In Reply to: Re: Farmall 706 Hydraulics posted by the tractor vet on April 21, 2008 at 13:53:10:
Hi vet, I've looked at the 706 drawings at caseih.com and can't figure out what you are calling the mcv valve. I've seen the term used on other threads. If you could ID the mcv by part number or parts drawing and its location I would appreciate it. I'm just trying to learn. My 2606 is similar to the 706 but it has a flow divider valve and control/pilot valve attached next to it and they are just left of the steering column. I just can't visualize the mcv on a 706. Thanks.
