Re: 504 loses power after an hour
Posted by David V on April 22, 2008 at 08:05:33 from (208.157.186.166):
In Reply to: 504 loses power after an hour posted by David V on April 22, 2008 at 04:24:33:
Update:
Today it won't start at all, generally it had been running fine after an hour or two break. There's good fuel flow at the carb and the carb is clean. Now that it won't start at all it seems more electrical, but other than the coil I can't think of what would explain it. The points only have about 150 hours on them, but the plugs are pretty old.
Hugh: This has been a great tractor for me, I get every bit of the 45hp out of it, I've got a 5-shank chisel plow I pull with it and I can pull it 10 inches deep without a problem, just not today!
