Re: H quits after only minutes of running
Posted by Janicholson on April 22, 2008 at 09:19:56 from (199.17.6.122):
In Reply to: H quits after only minutes of running posted by 160dan on April 21, 2008 at 20:33:45:
If there is a dead (worthless) battery in it, that is the issue. Even correctly operating charging systems need a good battery to regulate charge rates, and system voltage. If the battery is bad, the coil may be getting 20 volts! Make sure (with a good battery) that charge voltage is at 14.2 to 14.6 volts, and then lets go from there. JimN
