Re: LIGHTS
Posted by RustyFarmall on April 22, 2008 at 11:42:06 from (209.152.78.71):
In Reply to: LIGHTS posted by PRTZMAN55 on April 22, 2008 at 11:28:13:
Your light switch should have both a dim and a bright position. Are you on the dim setting?
This is assuming that you installed the original style flatback sealed beam lights.
If by chance you installed a set of the teardrop shaped lights, you probably have a 6 volt taillight bulb instead of the 6 volt "1133" headlight bulb.
