Re: Farmall 100 Need Help!
Posted by Glynn Moore on April 22, 2008 at 17:48:03 from (75.104.96.59):
In Reply to: Farmall 100 Need Help! posted by James Little on April 22, 2008 at 16:09:35:
If you have a 12 volt system, then you will need
a resistor on the 6 volt coil- Your hot wire from the switch to one side of the resistor-wire
from the other side of the resistor to the + on the coil---(-)from the coil to the distribitor
Hope this helps Glynn
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
