IHC 4568 V-8
Posted by :RIVIR on April 22, 2008 at 19:47:07 from (205.200.41.42):
had time too look at the V-800 engine that hasnt fired on the front two pistons, took the injecters out, started the tractor to see if the knock was still there, knock is reduced all right but crank case oil was coming out the injecter hole, 1 hole,where do you supposed the oil is coming from, i decided to fill the piston with diesel to see if piston was broken, but its holding full of diesel,any shots in the dark are welcome,at wits end, :~(
