Re: IHC 4568 V-8
Posted by Edpap on April 22, 2008 at 20:08:50 from (74.33.247.63):
In Reply to: IHC 4568 V-8 posted by :RIVIR on April 22, 2008 at 19:47:07:
Hello,
I wish i had the engine in front of me, it would be lot simpler. but the first thing that I would check is the injector, have it pop tested I have in the past when I had no choice hook the injector to its line and run the tractor. most times you have to bend the injection line to do and that could be trouble. there isn't too many other things maybe the turbo or maybe oil is building up un the valve cover and running down the guides but is sounds like an injector. If it was just pouring fuel in the cyl it would mix with engine oil and carbon and look like oil.
I can get you injectors for $75 each.
Good Luck Ed
