Re: Farmall 706 Hydraulic mystery
Posted by the tractor vet on April 23, 2008 at 07:58:15 from (76.212.237.9):
In Reply to: Farmall 706 Hydraulic mystery posted by Curt Cooke on April 23, 2008 at 07:48:12:
Well there could be alot of things going on here . With the low side out the sprag in the T/A is toast and there could be a bent lube baffel or the dump valve is sticking or the MCV pump is on her way out and the list goes on . SOOooooo to cure this it is time to replace the T/A and rebuild the MCV and install a new MCV pump and while your at it now is the time to do the engine clutch and PTO input shaft with a new bearing and all the seals along with grinding the flywheel . And if this is all done correctly it will last many years .
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
