Farmall 706 Hydraulic mystery
Posted by Curt Cooke on April 23, 2008 at 07:48:12 from (64.186.50.66):
My 706 has a torque but it's out on the low side. My oil light comes on with the clutch depressed and sometimes stays on even after I let the clutch out. I seem to be able to get it to go out by pulling the torque lever back and then pushing it back ahead. Sometimes it takes several times to get it to go out. What's going on? What harm might I do if I don't get this corrected right away?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
