mkirsch: Not completely so, if you just break into the high pressure line, use a power beyond remote valve, with the return heading back to the high pressure line to the touch control, it will work.
You can also achive the same without cutting the line, if you tap into the correct ports where the lines enter the touch control. I seen many a C and SC equipped with loaders and plumbing done that way. They could use either their remote or the touch control rockshafts with the touch of the proper lever.
Personally I tapped into the high pressure line of a Farmall 300 with a power beyond remote valve, ran the return from power beyond valve on to the hydra touch and I had 5 remote valves, 2 on the power beyond valve and the 3 factory on tractor, all available at the touch of a finger.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
