Re: Farmall 706 Hydraulic mystery
Posted by karl f on April 23, 2008 at 22:09:54 from (172.167.64.223):
In Reply to: Farmall 706 Hydraulic mystery posted by Curt Cooke on April 23, 2008 at 07:48:12:
isn't the light supposed to come on when the clutch is depressed even when the system works properly?
sounds like you have some issues going on from the other info you gave though, just don't want someone else to be alarmed if they read this and think they need a new pump when they don't.
karl f
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
