Re: Farmall 504 Transmission oil check plug
Posted by TractormanNC on April 24, 2008 at 04:57:30 from (209.42.180.151):
In Reply to: Farmall 504 Transmission oil check plug posted by Ken Hines on April 23, 2008 at 21:40:18:
If it does not have power steering, there is a 1/2 in. pipe plug on the left side of the transmission below the clutch pedal and forward of the LH brake. If it has power steering, the P/S and oil cooler return to an elbow which screws into the same opening. This is a special elbow which also has a 1/8 in. pipe plug in it for checking the hyd oil level. Hope this helps.
