What type of wide front? Factory tierod-in-front? Schwartz/aftermarket? Later tierods-in-rear IH?
The original wide front that comes on an H is not correct for a 300. It will fit but it will look wrong and detract from the value of the tractor.
If you don't care about how much the tractor's worth, that's fine.
One other consideration is that the original factory wide fronts do not turn very short. You will lose a lot of maneuverability. Hopefully you have the plate to mount the front end in the rear position to help with that some.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
