Posted by CNKS on April 24, 2008 at 17:25:50 from (216.144.104.128):
In Reply to: Farmall IH 300 posted by Tom Price on April 24, 2008 at 17:10:46:
Provided you have the float set correctly, it is a flow problem. You could have a restriction in the tank outlet. Take a flashlight and a wire, remove the gas cap and poke the wire through the outlet. It is possible, not likely that the vent in the gas cap is plugged, try it with the cap removed. There is a screen attached to the fitting that the gas line screws into. If you did not remove that fitting when you cleaned the carb, you did not see it. Otherwise you have a plugged jet. Did you soak the whole carb in carb cleaner when you had it off?
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
