Re: Farmall H drain on battery/bad starter?
Posted by CNKS on April 24, 2008 at 17:35:28 from (216.144.104.128):
In Reply to: Farmall H drain on battery/bad starter? posted by Dave Innerebner on April 24, 2008 at 15:33:18:
If it does it with the battery fully charged, it could be the starter button itself, or the cables are corroded or you don't have a good ground. My M (12 volt alternator) did that, it was the cables. The sparking is normal. I prefer to connect to the tractor starter last, preferably the ground away from the fuel tank and sediment bowl. I do it that way only out of desperation, I do not like those sparks.
