Posted by rbuckel on April 24, 2008 at 18:28:58 from (70.157.252.151):
In Reply to: super A steering posted by w croom on April 24, 2008 at 17:48:28:
My 47 A had the same problem. The arm from bottom of steering gearbox to tie rod assembly was loose on shaft. I was able to repair, but hardest part was removing the pin that holds front axle so I could drop bottom of gearbox to gain access. The steering gearbox itself was ok. After reassembly I filled steering gearbox with regular tube (3 tubes) grease (info I gleaned from this forum). I also replaced the bronze bushing and gasket in bottom of gearbox (picked up at local Case/IH dealer). Works great. If you don't have a manual you should get one. Some of the pros on this site may know an easier fix.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
