Posted by chuck davis on April 25, 2008 at 03:46:56 from (216.176.129.164):
In Reply to: super A steering posted by w croom on April 24, 2008 at 17:48:28:
i just went through this ordeal on my A. If you only have 1/2 turn of play(much like mine) it will probably be the steering gear arm and needs to be tightened. It is a major pain to get to and hard to really tighten properly. I took my axle off,redid all the seals and bushings in the gearbox. The woodruft key was tight as a drum. I also cut 1/16 of an inch off the slot where the bolt goes through the steering gear arm,this allows you to tighten it up more since it has probably been wrenched on many times and like mine the slot had been pulled nearly closed. The problem with of binding could be in the tie-rod ends,if they are adjustable you have to play around with them until tight but if you overtighten them they will bind,and of course grease or lack thereof will cause it to bind.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
