Re: SA fan
Posted by Jim Becker on April 25, 2008 at 06:55:27 from (71.170.201.34):
In Reply to: SA fan posted by Greg-N-CA on April 25, 2008 at 05:10:03:
Greg-N-CA said: I understand the reverse direction of groove on the shaft to push the oil away from the rear of the hub, but I just can't get over the fact that there is no seal on the rear end of the pully/hub.
As long as it isn't overfilled, it doesn't need a seal on the back side. The groove on the shaft is designed to draw oil back into the bearing, not push it forward. The shaft is stationary while the pulley moves! Be sure to get the impeller in the right way. The earlier Parts Catalog drawings have it backwards.
