Re: 560 wont stay running unless Solenoid is jumped
Posted by garytomaszewski on April 25, 2008 at 11:24:47 from (4.158.174.100):
In Reply to: 560 wont stay running unless Solenoid is jumped posted by ITFormulaGuy on April 25, 2008 at 07:58:01:
Should be two wires on the coil, one to where you are jumping on the solenoid,this gives you 12 volts to coil to help starting. The other is the run circuit from the "I" terminal of the ignition switch, it is either resistance wire or goes through a ceramic resistor to give you 6.6 volts so you don't melt coil/burn points. Start doing conntinuity checks and find out where the open is in the run circuit.
