Posted by John in SC on April 25, 2008 at 20:23:56 from (64.150.146.245):
Well here is an update.I received a gallon of hy-tran fluid today.It was recommended by the dealer. I drain out the other hydraulic fluid and replaced it with the hy-tran. Needless to say no luck. After a while I did find a weak spot. It started to leak around the connection rood on the d/s. I then proceeded to do a pressure test. I have a 0-200 lb gauge. I placed it on the high pressure side of the manifold tubes. At wide open the gauge only registered 15lbs, 2lbs @ idol. I can see why the lift will not work. : (
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
