Re: Message for Tractor Vet and others
Posted by MIKE FRENCH on April 26, 2008 at 20:47:46 from (76.0.8.19):
In Reply to: Re: Message for Tractor Vet and others posted by MAGMAN on April 26, 2008 at 15:35:56:
Rap the threads of the ta carrier with black tape and grease up before installing, this helps portect the seal if you dont have the special tool to install, once in place and the rear bolts are tight, remove the tape MAKE sure you get it all out, you can take a light and see most of the seal to see it. Been doing it this way for years and had lots of good luck.
