Farmall 504 Oil Leak in Axle Housing
Posted by LaVern Skarzenski on April 27, 2008 at 10:48:08 from (66.211.228.241):
Hi, I have a Farmall 504 Ser. No. 1132-S-Y that is leaking oil from the left axle housing and the differential housing. Looking in the I&T manual, it appears that the axle housing does not have a seal between it and the differential. So I assume the axle housing is supposed to be oil filled or at least have some oil in it. Am I correct? If so, is there a gasket between the two housings? If not, what do I need to do to fix the leak?
Also, what do the Letters S and Y in the Ser. No. denote? Thanks.
LaVern
