Re: Farmall H drain on battery/bad starter?
Posted by TheDurk on April 27, 2008 at 11:06:10 from (71.125.75.217):
In Reply to: Farmall H drain on battery/bad starter? posted by CenTexFarmall on April 24, 2008 at 15:33:18:
How did you determine drain? If your starter is weak, you may need 105% of charge to get it to turn over; then you think it has 'drained' after it has dropped normally to 95% of charge by sitting overnight. Recently, I was fooled by my 140 starter; changed cables, starter switch, etc. Finally, I attacked the starter itself and one brush mount had broken, meaning the poor thing was only half a starter. Now it spins that motor so fast it scares me (partly thanks to all the unnecessary work I did).
