McCormick Deering 10-20 weight
Posted by matt06br on April 27, 2008 at 23:06:14 from (206.253.48.11):
Does anyone know what a 10-20 would weigh. I did some research and came up with 3700 lb and 5200lb that is a big difference. I am just looking for a close weight because there is a big difference between 3700 and 5200.
Thanks
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
