Re: McCormick Deering 10-20 weight
Posted by ihc49 on April 28, 2008 at 21:30:59 from (216.123.197.173):
In Reply to: McCormick Deering 10-20 weight posted by matt06br on April 27, 2008 at 23:06:14:
the later ones came out with rubber and fluid in tires, which would make them hevier.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
