Re: Goo on A Oil Breather
Posted by RustyFarmall on April 29, 2008 at 06:12:12 from (209.152.78.71):
In Reply to: Goo on A Oil Breather posted by nyvines on April 29, 2008 at 06:02:38:
Basically what you are seeing is the result of condensation in the crankcase. I doubt if you have any leaks, although it is possible. Forget the stop leak. What you need to do is change the oil and filter, clean that breather, and then make that tractor work hard so it gets good and warmed up. That yellowish/white goop should disappear, or at least diminish.
