Re: H carb adjustment
Posted by Mike CA on April 29, 2008 at 07:57:06 from (214.1.211.251):
In Reply to: H carb adjustment posted by forgetful on April 29, 2008 at 06:17:20:
forgetful said: ...starting with the screw at the governor tube.
At the governor tube, that is the Idle Speed Adjustment. Factory setting for that is 1 and 1/2 turn out from seated.
Below that is the Idle Mixture (rich/lean) adjustment. I believe factory adjustment was 2 turns out from seated (I don't have my book in front of me)
At the bottom is the High Speed Adjustment screw. Initial factory settings were 3 turns out from seated.
Hope that helps.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
