Re: Questions about the famous 560 final drive fix...
Posted by Hoss in Me on April 29, 2008 at 14:34:10 from (72.224.133.167):
In Reply to: Questions about the famous 560 final drive fix... posted by CenTexFarmall on April 29, 2008 at 10:45:15:
460 and 560 tractors were orderedfixed by the factory.Change order #20624 in June 1959.This order was to gut the rearend and replacediff caserear axel anddifferential unit for the 460,560,and660New parts included heavier diff. case,tapered bearings,bull pinion,and brake shaft cage and bearing.Inner axel bearing was removed and reinstalled [in the place] where the outter bearin was,outer bearing was scrapped.A new tapered roller was then installed in its place and the whole shooting match was put back together. All as quoted by Ken Updike in his book.International Harvester Tractors 1955-1985 Later Hoss
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
