Re: Questions about the famous 560 final drive fix...
Posted by CNKS on April 29, 2008 at 17:31:07 from (216.144.104.128):
In Reply to: Questions about the famous 560 final drive fix... posted by CenTexFarmall on April 29, 2008 at 10:45:15:
Ken also states that not all tractors got the full package. Many got the inner bearing moved to be the outer bearing, which was scrapped, and the new inner bearing was a tapered roller bearing. When I bought my 1958 460 HU about 4 years ago, the axle had play in it. It did have the roller bearings. Due to cost I replaced then with ball bearings since it is highly unlikely it will ever see heavy use, certainly not by me. The serial tag does not have the triangle designating it had been fixed, so this could have been an owner modification and not part of the recall.
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
