Re: 140 Starter Help..........Please
Posted by KRS_MED on April 30, 2008 at 07:53:58 from (74.244.168.169):
In Reply to: 140 Starter Help..........Please posted by KRS_MED on April 29, 2008 at 17:44:05:
Hugh my late fatherinlaw did a few modifactions on this tractor! The 140 was built in 1967. It has a key start but does not have a solenoid on top of the starter. You switch the key to on an there is a push button like a old dimmer switch. On the starter the numbers 07328 as far as I can tell. The bendix does not look like the ones I have seen listed here with the spring. The bendix have teeth that engage then slide up on a shaft. I can take a few pictures if that would help also. I put the starter back together as best as I can by guessing. But I donot see how the bendix will return after it engages with the flywheel. Maybe I misplaced something.
Thanks For The Help!
Keith
