Hugh MacKay said: (quoted from post at 21:23:40 04/29/08) Keith: With a 140 you will have to give us a serial number. 140 had 4 different wiring systems during production. In those 4 changes the starter only changed once from pull rod starting switch on top of starter to key start with a solinoid. That will make a difference in the answer.
Having said all of the above, there have also been some backyard modifications.
I humbly beg to differ. While I am no guru, I have owned a 1966 140 since new and I am the only wrench that has ever touched it. There is no solenoid on mine, it just has a large starter button on the dash wired 4 gauge straight to the starter plus a separate key switch that energizes the coil. That's how it came from the factory. This is a very common Delco starter used in almost all GM cars of the time. I just had mine out (to fix a brush holder)and remarked on the same thing about the drive not retracting; the good news is it worked just fine when I put it in. I had some diagrams, which I will now look for.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
