Re: 9X24 tires for a 100
Posted by mkirsch on May 01, 2008 at 04:56:45 from (64.80.108.52):
In Reply to: 9X24 tires for a 100 posted by Patrick Martin on May 01, 2008 at 00:36:30:
Patrick, any 9-24 tire you find will probably be dry rotted by now, as that is the old sizing system used up into the 1950's.
9.5x24 is the equivalent size in the newer sizing system.
