Re: 9X24 tires for a 100
Posted by rich4 on May 01, 2008 at 15:22:27 from (74.60.110.90):
In Reply to: 9X24 tires for a 100 posted by Patrick Martin on May 01, 2008 at 00:36:30:
9.5 would be the replacement for old 9.0 Any increase in non stock tire size (10.2 or 11.2 etc) would speed up ground speed of your tractor, Then how wide is your rim, depends on what you are doing, you could drop down a gear maybe. when we went up one tire size on a Farmall C we allmost went too far for the gear we were using previously for heavy work. Keep that in mind, check circumference of tires and realize that when buying. Larger width tires are not just wider, but a lot taller.
