Re: 504 D188 engine swap
Posted by karl f on May 01, 2008 at 16:41:01 from (64.83.221.111):
In Reply to: 504 D188 engine swap posted by Tim38 on May 01, 2008 at 06:24:37:
anything can be made to fit. the use of frame rails from the factory help widen the possibilities.
least amount of modification would probably be the engine out of a 544 diesel, which is the upgraded version of the 504. I think the engine is a d239. be careful, as the block came in a frame rail version and an engine as the frame versions. I"m not sure if it"s the casting or removable parts that are different. others should know for sure.
karl f
