Posted by r4etired on May 01, 2008 at 18:16:04 from (166.227.144.227):
In Reply to: Farmall M Steering posted by Howard Schmader on May 01, 2008 at 10:46:27:
Remove the cover thats on top of the pedistal and check if the worm is running in the center of the gear. Normally as the thrust bearing wears the worm will ride above center, this causes it to be loose.Make a spacer washer the thickness the same as the worm is above center and place it on top of the thrust bearing, Lots of bearings have been replaced that adding a shim would have saved for a long time. The 400-450's were bad for this,I have shimed them as much as 1/8in.There are several other contributing factors causing loose steering but most are noticeable. Good Luck
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
