Re: cub rotor button
Posted by MAGMAN on May 02, 2008 at 05:34:03 from (69.19.14.21):
In Reply to: cub rotor button posted by tubby on May 01, 2008 at 19:03:44:
Tubby,
Most are off base here, A H4 mag rotor is nothing like a J4 what you need to to is. There is a small line in the rotor material and its runs down to the gear on the rotor and will match up between 2 teeth..
Its exactly opisete the tang that fires on the cap.
If you need help I can send you a pic of a j4 rotor with it inscribed.
JON
