Re: Super A Sediment Bowl Leak
Posted by NawlensGator on May 02, 2008 at 07:33:58 from (52.129.12.48):
In Reply to: Super A Sediment Bowl Leak posted by asyrp43 on May 02, 2008 at 07:07:24:
Mine have a nut below the bowl the that I tighten until the top rim seals against the top gasket sufficiently that it doesn't leak. Before I turn off the tractors I always turn the lever you mention to stop gas flow to the carb. I let the tractor run out of gas and only turn the key off after it stops running. This avoids some carburator problems that can be troublesome.
