Thanks for the answers. This place is great! I have the nut tight and the bowl is sealed but the cut off valve is where the leak was coming from. I can't remember which way but I turned it until it stoped and it runs fine with no leaks. I guess that is open. I will try turning it off next time I use it and see if that helps. It seems to only leak when it was half way between open and closed. I just wasn't sure what the valve did. Thanks again for all the help!
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
